Need help!!!!!need help!!!!!need help
tonytygar912
ItRyHaRd
I recently purchased (4) audiopipe TXX-BD12 1500W 12" SUB WOOFERS, a KICKER ZX2500.1 AMP, (4) AUDIOPIPE SPEAKER LOW MID FREQUENCY 6" LOUDSPEAKERS.....I WILL BE PURCHASING A 4 CHANNEL AMP, ABOUT (6) SUPER TWEETERS AND (4) 6 X 9s. I NEED SUM OPINIONS ON WHATEVER I NEED 2 GET TO HELP THIS SYSTEM WORKING RIGHT(BATTERIES, WIRES, ALTERNATOR SIZE, ETC OR ANYTHING ELSE U THINK I SHOULD ADD) I WILL BE PUTTING THIS N MY 1972 2 DOOR CHEVY IMPALA...I ALREADY HAD A BOX BUILT FOR THE SUBS.
Basics really....
Upgraded Alt(budget?)
Battery bank(budget?)
1/0 wire
Big 3
RCA's
Remote wire
Voltage gauge for upfront to monitor the voltage while you are playing the system
ok so i have 0awg wiring kit i wanted 2 know if i needed 2 fiberglass my doors because im planning on putting (2) 6'' loudspeakers and (3) super tweeters in each door.....WOULD DAT BE A GOOD IDEA
You only need 1 super tweeter per each door In your case. Generally you only need 1 super tweeter for every (2) 6.5", (1) 8", (1) 10", etc. If you want 3 tweeters in every door, then use 8 ohm bullet tweets.
I think you missed the idea of what his build is about. It is not actually about the sound being reproduced.
Figured I actually help out instead of making fun or criticizing the guy for using AP equipment. Lol
---------- Post added at 04:48 PM ---------- Previous post was at 04:48 PM ----------
Just loud noise.
True
tonytygar912
ItRyHaRd
tonytygar912
Uvalda, GA
Flex68
