Need help mids highs amp b
KingJay
ok i hooked up my subwoofer amp and everything but i never hooked my highs and mids to an amp so i need some quick help............4 6x9's 4 tweeters 2 5.25speakers and 2 4x6 speakers........i have a splitter for RCA's i have a splitter for power and ground and remote wire...........so whats next Guide me threw it please. also the amp is a Lanzar VIBE438 4 channel amp.Do i hook it as if i am hooking up subs by not running the speakers to the deck but straight to the amp? also when setting my deck for the subwoofers wont that affect the way the high play like when i put the bass up on the deck wont it go threw the highs or when i set amp B i just have to take all the bass off? help me out because i know everythin else but how to hook a amp b for mids highs etc.........Thanks to anyone who helps
1st off you're not going to be able to power the 12 speakers on that one amp. 2nd why on earth do you want to?
Connecting speakers to an amp does not change. You connect the RCA's then you connect the speakers to the amp.
I mean i have those speaker and i want them louder........OK well help me on this how many should i connect to it just the 6x9s and the 5.25 i will do? i really needed to know about the setting how do you usualy setup the amp for components? tell me that then i am good to go. I know about the rca etc.......ok from the deck when i set it for the subwoofers i know i usually use the bass boost on the deck and keep my gain low on the amp......will that affect the speakers ????
KingJay
KingJay
New Iberia, louisiana
Blunt
Mike Mccabe
