mopower440
long story. I have a small 4-channel kenwood amp i always used in 2 channel bridged mode for a sub and ran my door speakers straight off the radio being it was a single cab truck i didnt need much power for the door speakers. Well, i recently bought an extended cab truck and planned to use this same amp in 3 channel mode, the front channels for the door speakers and bridge the rear channels for the sub. So it would be 16 watts to the door speakers and a bridged 45 watts to the sub.. all good except my new pioneer head unit is rated at 16 watts rms also! so, is there any point in running my door speakers off the amp then since the head unit is rated at the same wattage as the amp or would the amp still help for some reason? Here is the specs on my amp,,
KENWOOD KAC-644 4 CHANNEL AMP
Specs:
Max Power Output (4 Ohms)
4 Channel Mode: 40w x 4
3 Channel Mode: 40w x 2 + 90 W
2 Channel Mode: 90W x 2
Rated Power Output (4 Ohms)
4 Channel Mode: 16w x 4 (20HZ ~ 20 kHZ less than 0.08% THD)
3 Channel Mode: 16w x 2 (20HZ ~ 20 kHZ, 0.08%) + 45 W x 1 (1 kHz 0.8%)
2 Channel Mode: 45w x 2 (1 KHZ, 0.8% THD)
Rated Power Output (2 Ohms)
4 Channel Mode: 25W x 4 (1 KHZ, 0.8% THD)
This amp always seemed like it put out more than its rated at, it will thump a 10" sub quite well!
Specs:
