need help from the computer guys.
Could be corrupt or uninstalled drivers. Was this a fresh install after downloading too much pr0n?
Also you can go to tools/internet options/connections/lan settings and make sure the automatically detect settings is checked
Or go to start/run/type in cmd ........... then type in ipconfig /release then type in ipconfig /renew
then while you're still in cmd, type in ping (laptop name) see if it gives you an IP address.
it gave me options
click start in the bottom left hand corner, click the connect to go to show all connections....disable the wireless connections by right clicking on them and clicking disable. Make sure the Local area connection is enabled. Move the cursor over the local area connection, right click and hit status and tell us what it says
or hit "repair"
has this laptop been used on this router before? if no i say drivers
i guess i shoulda said to plug the wire in and stay off wireless
You have just received the Amish Computer Virus. Since the Amish don't have computers, it is based on the honor system. So please delete all the files from your computer. Thank you for you cooperation.
yes it has been used on the same router befroe they moved. he called dell and they said that he deleted the local area connection?
deleted the LAC huh? tell him to do what i suggested.....if he has no LAC then he needs to create a new one...its pretty simple to do....but his wireless doesn't need a LAC just a wireless connection i believe
how do i create a new one
click start>connect to>show all connections on the left side of the connections hit create new connection>follow directions
when i do that it give me options and the only thing i can do is pick from isps and the only option is msn
spike_e
ballin on a budget
spike_e
prattville AL
bonesninja
