Need Help Finding Amp Kit
ddog003
Hey, I just got 2 Infinity Kappa Perfect 10.1d subs and an Infinity Reference 611a amp to power them. I was just wondering what would be the ideal amp kit for this and if anyone knows where to get one for a good price. I am also a bit condused on how I should wire my subs to my amp. Is this amp good for these subs? Here are the specs below. Thx.
Each Sub
Rec. Sealed Box Dims: .6 - .6 cu.ft.
Rec. Ported Box Dims: 1 - 1 cu.ft
Free Air Usage: not recommended
Sensitivity: 94 dB
Frequency Response: 18-150 Hz
Recommended RMS Power: 350W
Peak Power Handling: 1400W
Impedance: dual 4 ohms subwoofer wiring options
Amp
Amplifier Type: Mono
RMS Power: 456W x 1 @ 4 ohms
THD at 4-Ohm RMS Power:
Bridged RMS Power: 657W x 1 @ 2 ohms
Speaker Level Inputs: no
Preamp Outputs : yes
Built-In Crossovers: LP
Bass Boost: 0 - 12 dB
Frequency Response: 17-302 Hz
Signal to Noise Ratio: 70 dB
Fuse Rating: 2 x 30 amps
Each Sub
Sensitivity: 94 dB
Amp
tolk to dbman150he can hook you up
ddog003
ddog003
Phoenix, AZ
keifersracing
