Need Help Eliminating Buzz When Using Stereo Aux In
ryevick
I drive a big truck OTR and I use my Droid X phone as my MP3 player (it holds a lot and sits in a window cradle)... If I try plugging it into the Aux Input in the truck's stereo while it is being charged by my Cobra 1575 power invertor it makes a loud static buzz... if I try doing it when it is being charged using the cigarette lighter adapter it makes a loud whining buzz that increases in pitch and volume the faster I drive... if I plug it in without charging it, it plays fine but I drive all day and it needs to be charging when in use. Is there something I can put between the Cobra invertor's ground cable and the battery ground post to eliminate this or what? I am not too knowledgeable on this stuff but I would guess it's some kind of ground problem when a loop is created or something. Please help! Ideas, suggestions? Thank you! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You use a AUX cable? Try a ground loop isolator, plug it into the AUX connection on ur truck, then plug ur AUX cable from ur mp3 player into the isolator.
ryevick
ryevick
Atlanta, Ga
ryevick
