Need Help Designing A Box
post up the design. also was the noise worse from the sub at higher frequencies compared to lower? if so you my friend might have a burnt coil and or coil rub. check the coils with a DMM to c what they read in comparison to proposed impedance.
the only problem i think i came across is the wiring to the amp . ther r two sets of positive and negative terminals and usually i would brigde them but the wiring diagram said nothing to do so
found my problem . the dustcap was coming off so i glued the cap back on and no more noise and works perfect now . but i noticed i wasnt able to hit the low notes like before any suggestions on a new box design ?
If you're not hitting the low notes like you want to, then it seems like tuning lower is the logical answer. Have you used test tones to see where it is you're actually not happy with the output? "low tones" can be in different areas according to different people.
chevyfan13
chevyfan13
san antonio tx
manosteel916
