need help deciding
littledude
MI
well i just got my new Brutus bxi2006d amp in, and i wired it up to my 2 12"type R's at 1 ohm, which is supposedly 1000w rms but probably a little less, well any way my subs don't like the power and i wanted something a little louder, but i don't have much more room for a bigger box, so i was thinking of buying one 15" sub, which is where i have a problem. i don't know which kind i want, I've been looking at the kicker l7, but i don't know, i want a dual 4 ohm so i could run the amp at a 2 ohm load which would give it 1300rms, would i have no problems with this little extra power ill be giving, it, i have alot of mdf lying around, so i could build a box at 3.f-4.0cu.ft.
any ideas,
thanks
ya, i'm really looking at that hd3 now, wire my amp down to 1 ohm on it, would a 3.5 cu.ft box tuned to 40hz make it pound real nice???
one more question, where can i order it at, i went to there website and, i cant find where i can order it from??
order form... under products tab.... I'm bout to order one too. Same amp. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks man,
be sure to pm me about how you like it, when u get it, because i don't know when im going to be getting a new sub!!
also what kind of box are you going to use??
What kind of box are the subs in? Sealed, ported, tuning? What kind of coils? And the BXi2006D puts out 2000W RMS at 1ohm...not 1000...
sorry... I meant 1000rms to each one.... 1.82 per chamber, 38hz, ported.
the coils are dual 4 ohm
sorry... I meant 1000rms to each one.... 1.82 per chamber, 38hz, ported.the coils are dual 4 ohm
That box is //content.invisioncic.com/y282845/emoticons/sick.gif.b1847c8dabbfeeddbcf1a78052249e10.gif
Dont but a new sub before you do this:
Rebuild your box for 4.5 or 5 ft^3 net, tuned at 34hz, with about 60in^2 of port...
After you do that, and are still not satisfied...then get a new sub.
littledude
littledude
MI
j3bus2k3
