need help deciding on home audio setup
I dont know the real mechanics behind a driver but I would say one thats designed to play in the open environment like a room would have the edge when used like so compares to the type-r, a driver designed to work in the mobile audio area...but then again, I'm no expert. Bottom line though, that dayton 12" High Output woofer with the 1000w plate amp would be my baby in an instant if I had the money right now....
if you arent using a sub out on a receiver using a plate amp is definately easier, you could use the "tape" out on the receiver as usually that sends the signal through no matter what mode it is in
these subs kick ***, look great and are a great value:
http://yellow.mynethost.com/~bv126368/shop/catalog/product_info.php?products_id=53&osCsid=e17249e9728b37e89e41dbe74446a1d5
dual sub, single enclosure use this amp:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-808
dual sub, two enclosures use two of these:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-752
pimpedout97x
Tampa, FL
Scoobydoo
vegang
vegang
