need help deciding on home audio setup
Well, since your gonna be running that for a sub amp your going to need a crossover. The cheapest ones ar ethe Behringer CX 2310, also ART and RANE make/made ones that are basically the same as the behringer on ebay for around 50-80 bucks. You HAVE to get a crossover with a SUB OUT on it too.
What is your main amp?? What are your mains??
You might consider getting a badass plate amp instead of going rack gear, cause once you get the amp, then your needin a crossover, then your gettin a preamp to up the voltage to pro audio levels where the amps are made to run. Then end up doing what I did and just going full rack gear... All because you wanted a **** crossover... hehe
cant decide between the Dayton Titaic MKIII 15" or a 12/15" 05 type R....help me out!
i dont think you meant to put in that 12" for the Type R did you?//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
indeed i did.
no i dont think you understand...you didnt..oh and what if i looked like that --->//content.invisioncic.com/y282845/emoticons/wacky.gif.cf4a48f9e6dfe9504ffd2c946fd2f340.gif
PS - Dont say i already do...already thought of that comeback
OOPS WTF?!?!
It was supposed to be your 1000 watt plate amp.
Ive heard great things about that sub, im sure it would out perform a type R 12 no problem
what about a type R 15??//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
pimpedout97x
Tampa, FL
Scoobydoo
vegang
vegang
