Need Help Choosing an Amp
I have a 2007 honda CR-V and I'm installing two 12' 18 sound 12mb1000 midrange loudspeakers and three beyma CP22 Super Tweeters and one 18 sound HD2080T 2' HF Compression Driver which will be put into a cabinet speaker box in my car and a for subs Kicker Solo X 18 Dual 4 ohm if any one has any suggestions on amps to power all this i thinking of running a two channel amp for the two midrange speakers and a four channel amp for the three tweeter and Driver any ideas and amps recommendations
18 Sound 12MB1000 Specs:
Nominal Diameter 300 mm (12 in)
Rated Impedance 8 Ohm
AES Power 600 W
Program Power 800 W
Peak Power 1600 W
Sensitivity 102 dB
Frequency Range 80 ÷ 3500 Hz
Power Compression @-10dB 0,5 dB
Power Compression @-3dB 1,5 dB
Power Compression @Full Power 2,1 dB
Max Recomm. Frequency 2500 Hz
18 Sound HD2080T Driver Specs:
Throat Diameter 50 mm (2 in)
DC Resistance 6,2 Ohm
Minimum Impedance 8 Ohm at 3500Hz
AES Power 100W above 1,2 kHz
Program Power 200W above 1,2 kHz
Sensitivity 109 dB
Frequency Range 500Hz ÷ 20kHz
Recomm. Over Frequency above 800Hz (12dB/oct slope)
Beyma CP22 Tweeters Specs:
Impedance 8 ohms
Minimum Impedance 8.5 ohms @ 9.0 khz
D.C. Resistance 6.1 ohms
AES Power Rating 25 Watts
Program Power 50 Watts
Sensitivity (1W/1m) 107dB SPL
Frequency Response 4kHz - 20kHz
Recommended Crossover 5.0 kHz or higher
Dispersion (H x V) 40° Conical
Voice Coil Diameter 1.5" / 37.6mm
Magnetic Assembly Weight 2.64 lb. / 1.2 kg.
Flux Density 1.55T
BL Factor 5.2 N/A
Kicker Solo X 18 Specs:
Subwoofer Series SoloX
Subwoofer Size 18"
Peak Power Handling 10,000 watts
RMS Power Handling 5,000 watts
Voice Coil(s) Dual
Impedance (Per Voice Coil) 4 ohms
Voice Coil Diameter
Frequency Response 18 - 100 Hz
Sensitivity 90 dB
Xmax (millimeters) 24.5 mm
I have a 2007 honda CR-V and I'm installing two 12' 18 sound 12mb1000 midrange loudspeakers and three beyma CP22 Super Tweeters and one 18 sound HD2080T 2' HF Compression Driver which will be put into a cabinet speaker box in my car and a for subs Kicker Solo X 18 Dual 4 ohm if any one has any suggestions on amps to power all this if any one has any suggestions on amps to power all this i thinking of running a two channel amp for the two midrange speakers and a four channel amp for the three tweeter and Driver any ideas and amps recommendations
DrzCrazyNigga
DrzCrazyNigga
Milltown NJ
DrzCrazyNigga
