Need help choosing amp
Alright I like that Hifonics one, so i can use 2 subs with a mono amp?
You could also go with this POWER ACOUSTIK 3000 W CLASS D AMP
its about the same price as the hifonics
http://www.rickiesdiscountelectronics.com/power-acoustik-3000-w-class-d-amp-5407.html
You might want to also try this BOSS CLASS D MONOBLOCK AMP W SUB LEVEL...it is 4000Watts@1 ohm and its only $219.99
http://www.rickiesdiscountelectronics.com/boss-class-d-monoblock-amp-w-sub-level-cont-9974.html
or possibly this BOSS CLASS D MONOBLOCK AMP W SUB LEVEL CONT..its 5000 Watts@1 ohm...its only $249.99
http://www.rickiesdiscountelectronics.com/boss-class-d-monoblock-amp-w-sub-level-cont-9975.html
i can tell as the guy said above there aern't many amps with that wattage at the price that you're wanting...the boss & power acoustik stuff is decent stuff for the money
The hifonics amp is a good amp also but it is about $300....the ones i mentioned are probably the only ones that are around $200 and some of the smaller companies like soundstorm..etc
Yes you can use your subs with a mono amp...your subs are dual 4 ohms....& you have two so....you will either have a 1 ohm load overall or you will have a 4 ohm load overall if it is going into one channel mono amp....most of the time the max wattage of a monoblock amp is the wattage at 1 ohm, but not all the time...
TheIssue
TheIssue
michigan
TheIssue
