Need help calculating rectangular shaped port
Pantani
If I have a known circular port length of 2.5" x 11.25", how do I come up with the displacement in cu. ft. of this port so I can figure out the size of the rectangular port I would use?
I have 2 8" Rockford Fosgate HX2's (RFD2208) and am looking to put it in a ported box, tuning around 32ish Hz.
That is the recommend diameter and length given by Rockford in their manual for this sub, but only for 1 sub. I was just planning on doubling the volume for the sub, and doubling the volume of the port for my set up.
Using WinISD I came up with a box tuned to 30Hz w/ a single port size (for both woofers) of
Box volume: 1.291 ft^3
Port size: 4.02" x 2' 1 15/16" or .190 ft^3
Doing the math, if I simply double the volume of the recommended port size from Rockford I get a port measurement only about .01ft^3 between what WinISD says vs. Rockford.
Pantani
Pantani
St. Louis
Pantani
