Need Help ASAP
Id check the RCA connections, to see if you hooked the wrong ones up by mistake,like ft,or rear..Ive been guilty of that in a rush,,Headunit settings/sub woofer control..Amp LPF Switch ..make sure its on, be careful, and be sure the gain is down/not maxed out..Remote wire connected to the headunit, and amplifier
Checked RCAs. They confuse me I have 2 sets of the standard red/white RCAs but I also have a place that says "SUB OUT" but it's only takes a single wire hook up. It throws me off bc to me it should have a place for two, red and white. I have messed much on headunit. I thought I would atl least get something out of my subs.
Sub signals are mono, hence the reason for one RCA jack. You can sum a stereo signal to mono using a splitter or you can just make sure the same color of a pair is connected at both sides.
Gave up for the night. Still same problems. Amp powers on at 14.5 volts and remote wire is intact but no sound/signal to subs at all. Guy I got the amp from SWEARS it was not defected when I got it. Just trying to troubleshoot this problem.
Subs were wired in the box but when I noticed nothing was happening I redid everything and just set a sub outside next to the amp with a quick wire connection just to see if I can get power.
BNolan12
BNolan12
Lafayette, LA
BNolan12
