need help/advise
keegans
hey i have just got a new sound system it is 2 15inch fusion PP subs powered by a soundstream pca2000d,, but when i turn my car off the amp is still running the green light stays on? and when i listen to music now there is a werid noise coming though the speakers now like a squeeky/buzzing noise
If the amp stays on when your car is off, the remote wire is probably hooked up wrong. Check to see if you have any split hairs off the power wire touching the remote wire terminal on the amp, & make sure it's hooked up properly to the right wire behind the deck.
As for the noise, where are your rca's ran at? if they are right next to the power wire run them along a different path away from it.
keegans
keegans
new zealand
9seconlives
