Need help about these speakers I bought.
View attachment 26555244View attachment 26555243I have bought these subwoofers used, with simply barely any deep knowledge about them .
I'll tell you what I do know:
They are inverted in a bandpass box.
The drivers are (2003 series) MTX Thunder6000 (don't know if they are duel 4 ohms or single, how would I tell?)
Can someone help me in the direction of wiring, and which amp should I buy?
Also, anything else you feel like you need to tell me (ie reason the box is like this)
i know it's old af. lmao but im looking to get started with these.
Here are the specs.
Dual voice coil will have 2 positive and 2 negatives to hook up to the amp. One of each for each coil. Once we find out which one it is, choosing an amplifier is possible
Sent from my SM-N920P using Tapatalk
I have a MTX RT12-200 12-inch Road Thunder Speaker with a built in amp and recently it stopped working suddenly and I inspected it and found that the rca cable connection was very loose and I was hoping someone could have an answer on how to fix it. I don't want to buy anything unless I have to and was hoping maybe if only have to buy a new rca cable and it wasn't the connections in the amp that were busted. Thanks for your help!
AndrewLeblue
AndrewLeblue
Lake Charles, LA
Jhcranford5
