Need Help, 15" Q
Gunlex
WA
Im under space constraints..I'm making the heigh only 15.5", and going to have a chamfer on the top and bottom panel around where the sub is, thus allowing it to fit. I have figured that i can go with a depth of 22" and a width of 32". I figured out using the RE website taht the volume would be 3.788 ft^3 with a Freq of 29.68.
Dimmensions:
H - 15.5"
W - 22"
D - 32"
Vol - 3.788 (3.6 after displacement)
Freq - 29.68
Port width - 4"
Port Length - 15"
Total port lenght - 39"
Is this looking good? The site says 2.8-4cu ft and 28-33Hz. My main concern was the phase of the box...I was told the phase was going to be a little off...
i guess a "yes, it looks good" is hard //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
bump.
If you knew that program could be off, why did you use it? WinISD is free and takes 3 seconds to download.
I can't check for you at work but I think it looks good. The dimensions are very close to my Fi Q 15 box which is 3.5 cubic feet at 33hz.
Also the inner diameter on a 15'' Fi Q is 14 1/8'' so make sure you build your box in a way that you have the full 15.5'' of height on the front panel.
Gunlex
Gunlex
WA
spoonraker
Mike Mccabe
