need good amp
I OHM STABLE D CLASS MONO BLOCK AMPLIFIER
* LOW LEVEL INPUT AND OUTPUT
* FREQUENCY RESPONSE: 20Hz~350Hz
* INPUT LEVEL: 0.2V~6V
* VARIABLE SUBSONIC: 10Hz~50Hz AT 24dB/OCT
* VARIABLE LOW PASS FILTER: 35Hz~250Hz AT 24dB/OCT
* VARIABLE BASS BOOST: 0~9dB AT 45Hz
* REMOTE GAIN CONTROLLER
* TWO AMPLIFIERS LINKABLE CONNECTOR AND SELECTOR
* FUSE RATING-400 AMPS, LINKED FUSE RATE, 800 AMPS, USES EXTERNAL FUSES
* EXTERNAL FUSES AND FUSE BLOCKS ARE NOT USED
5600 Watts at 14.4 Volts
6500 Watts at 18 Volts
* Width: 9.5"
* Height: 2.25"
* Length:25.75
American Bass - VFL 500.1
dewayne22
dewayne22
Indiana
PowerRANGER03
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
