Need Design And Cut Sheet Asap
You might want to start with your maximum dimensions, sub types, power, vehicle, and what you want from them. Wow...
I could throw up all kinds of designs and cut sheets for you but they won't be worth a **** if they don't meet your needs.
2 sheets thick on all sides and top
3/4 thickness
bottom i can manage 1 sheet
4 -18s
need 10.75 mounting depth
sub displacement
0.25 each
dimensions to work with:
47w
40 l
25 h
i have room to adjust height to make up air space if needed
300 sq in of port total
150 sq in each port
i would like 1 port on each side toward the rear of the vehicle
tuned to 38 hz
front of the box i need a ledge built to place batteries under on their sides
width of the box
12 wide
8 deep
6.75 height
need 16 cu ft after displacement
thats why i stated i can go up in height if i need to. just those are the dimensions to start with
width and length can not change
height i have plenty more space
they are gonna need to know how tall you can go cause the space you gave wont come close to what you need.... why not contact one of the designers ? they dont charge that much and are quick
I mean, if you had asked if anyone would make you a design, and had listed what you like listening to, your MAX dimensions (not this can be bigger if need be, you need to say what it can go up to), and oh I almost forgot: THE ****ING SPEAKERS YOU'RE USING.
PV i said i was using 18s and the displacement
anything more than that will be bracing on my part just was wanting some help with the box.
which is taken care of pics will be up as i get started
18s. There are thousands of speakers with that parameter. You do realize box design isn't beating off onto the keys and seeing what pops up.
yes very aware. this isnt my first system. ive been doing it for 8 years.
ive just never done something this large
to make you happy im using
4 MT 18s
so in other words there arent really any parameters
4 MT 18s
i need to go get all the wood today. i need a design and cut sheet ASAP
Let me lay it out to you why I've said what I've said. You posted this as the first post in the thread. It says nothing whatsoever about what you want. I have a design for a 4" subwoofer sitting right next to me. You wouldn't want that, would you? Then, you stated that you need some monstrosity with intricate compartments for four unnamed drivers which will be fed massive amounts of power in a vehicle that doesn't have a name. THEN, you continued saying that you were actually experienced, but if you'd even thought for a minute, you'd realize that an enclosure that is 16 cubic feet for four of the nastiest drivers out there with an amp and battery compartment is NOT something that is made ASAP, far let alone something that you get your wood cut at lowes for. Do you understand me now?
yes i realize there are a lot of things that werent there. all i was doing is asking for someone to contact me. at that point all information needed would be given.
Isn't 4 cubes each on the small side for MT's? I built a box for a single MT that was 8.5^3 @35Hz and it pounds the lows. I just built what the customer wanted, but it sure seems to like that big box...
it would be if i was putting 5000 watts on each. with that power i have they will be good from 4-4.5 cubes each.
that coming from RE
im using 10k total so 2500 each.
this isnt an all out SPL vehicle
its a daily driver
the vehicle being a 97 4door tahoe
that takes me back to an earlier post. MORE THAN ENOUGH SPACE
just dont want to lose the back seat since its a daily driver
bones22
bones22
in my house
bones22
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
