Need Audio Expert Help!
Rukuzz
I have a sony amp 2150gsx bridged 380w running 2 15" punch series 1 woofers.
I've noticed the lights on my truck (2001 toyota tundra) lights dim when the bass hits hard (mostly with rap music).
Will a 1farad or .5farad cap be enough? I'm not a comp guy just looking or something nice sounding. I'm looking to switch to 2-JL 10wOs because one of the 15"s is blown & I wan to have enough power for the JLs.
Has anyone heard of the Tsunami caps
It would be a far better idea to either rewind your alternator, or get another battery. A capacitor merely alleviates the pressure on your electrical system when it is working properly (no light dims) and helps it to run more smoothly.
Does it make a difference that the dimming only happens at a stop? I'd think it'd be kinda expensive to get a new alt. or rewind it! My truck is farily new & I'm not into competition. I'm hoping the cap may relieve the pressure on my electircal!
Any ideas
Don't listen to that kid. from what your saying you want a cheap yet good fix for you current problem, right? if so, a cap is the perfect solution. it's cheap and it will fix your problem with your lights. i had the same problem with my car and i threw in a 1farad cap and my lights don't dim any more. the rule of thumb for cap sizes is: for every 1000W your system puts out, you should use a 1 farad cap. so if you put 500w you'll get a .5 farad cap, but if you put out 1000w you'll need a 1 farad cap, and so on. so if your pushing 380w get a .5 farad cap. it doesn't really matter what cap you get because they all are almost a like, no real differences. some might come with a volt meter.
hope this helped
lata
I think for now I'll go with the 1farad Tsunami cap just incase I decide to upgrade my stock speakers later on.
I have a toyota tundra and the alt. would definetly be very expensive rewound or higher output.
When I first started this I never thought I would be talking wire guages, caps, speaker and all this other stuff.
I've created a monster of myself!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
And my pocket is taking a large hit! LOL!//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
Bassbox pro requires many t/s parameters some of which arent on the skar audio website. This is my first time searching for t/s parameters online...
258
Rukuzz
Rukuzz
McAllen, Tx
mr.cableboi
    May 24, 2024
    May 23, 2024
