Need An Amp!!!
alphasonik 1000hca $225 shipped to you...
1000hca:
2 Channel High Current Power Amplifier
RMS Power Rating: 3000 watts x 1 chan. at 1 Ohm Mono
RMS Power Rating: 1500 watts x 2 chan. at 1 Ohm Stereo
RMS Power Rating: 900 watts x 2 chan. at 2 Ohms Stereo
RMS Power Rating: 500 watts x 2 chan. at 4 Ohms Stereo
Hour Meter to log amplifier usage
Remote mount Bass Remote control included
Remote mount Digital Voltmeter included
ANL gold-plated Fuse Holder included
Heavy duty heat sink
Beveled clear acrylic protective cover
Tiffany-Style input and output RCA jacks
High speed switching power supply
Double-sided glass epoxy circuit board
S/N Ratio: >100dB
Frequency Response: 5Hz-50kHz
Variable low pass filter: 50Hz-250Hz
Variable high pass filter: 50Hz-250Hz
Variable subsonic filter: 15Hz-60Hz
Variable bass boost at 45Hz: 0~+18dB
Variable phase shift: 0~180 degrees
Input sensitivity: 200mV-8V
Input impedance: 10K ohms
4-Way protection circuitry: thermal, short circuit, overload, and DC offset
On board hook-up terminals
Dimensions: 26"L x 9"W x 2-5/8"H
aaronmj
aaronmj
pacific timeee
aaronmj
