need an amp!
money isint that important...but should be a reasonable price...u know something good!
after all i did invest in alpine type r speakers so i need something good to power them
What about a Kenwood KAC-X541?
here are the specs:
Kenwood Excelon 960 Watt Bridgeable 4 Channel Amplifier
Continuous Power Output @ 4 Ohms Stereo: 60 Watts (rms) x 4
its just 5 watts rms over for the back
and 10 watts for the front
would this cause a problem?
Depends on where the gain is set in relation to the input voltage from the pre-outs ...
heres the input voltage for my h-u : Pre Output Voltage (Before Clipping) : 4 Volts
im not shure if thats what u meant tho
and what do you mean by what you said??
please explain a little....im not a pro //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Wow...this is really confusing.
ill try to make what i can from what you told me.
thanks alot!!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Wow...this is really confusing.ill try to make what i can from what you told me.
just read the gain tutorial. more speakers will die due to clipping then overpowering. if gains are set properly there should be no problem.
tip-c
tip-c
montreal
iceteebone
