need An amp to push Pioneer TS-W3002D4 12 In. Champion Series PRO Subwoofer plz help
mokei
6
APO
Whats a good amp or amps i can use to push those 2 subs i got coming. am sooo lost haha i got a Kenwood KAC-9104D but friends say that will not push that they way in needs to be pushed. thank you guys for your time. some that wont break the bank ither hahaa a lil new when it comes to car audio //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
peace/blessing
what is your budget? You will need 2000rms. Have you measured for a box yet? do you have room for 4 or 5 cubes of box? did you upgrade you power charging system yet. 2000rms will draw a hell of alot of current and cause issues. do it right the first time... Sounds like you might need to save up $800 or so. What kind of car are you planning on installing all this in?
hell ill buy 2 of those:) i dont have 800 to spend at once but i want to know what do you suggest? Again thank you for ur time
Well for now just use one sub, one amp. first things first.... run 0/gauge and get a second deepcycle sealed battery for the trunk. pick up distribution blocks, battery terminals, heavily shielded RCA's. If you have a box for a 12, you can use that until you have the money to build a custom box for the pair. Run the power wire and second battery first. Then get the second amp, then build the box. IF you decide to go with more power, you may end up having to upgrade your alternator. Also.... Look into "The big three" on this forum. search for it and read up about it. also read up on clipping and gain setting....
thanks man ll go get one of those subs and just use one sub for now. My boi did the big 3 in his car soo lll have him guide me as well after reading up on it. Again thank you for your time
mokei
mokei
APO
mclerico83
