Need an amp to Power 2 x 15" FI Q's
bigp69
Selling 2 Ps3s (60GB) New
Hey again :p,
Ive decieded to get 2 15" FI Q's. Now i need to find an amp to power them. It needs 2000 W @ 1 Ohm right? What do you guys suggest. I have only found one potential amp so far. Soundstream Picasso PCA2000D. Any good amps you can recommend to power these?
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Q15
DUAL 1 | DUAL 2
Fs: 25.9 Hz | 24.9 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.64 | 5.72
Qes: .54 | .54
Qts: .49 | .49
Mms: 257g | 279g
Cms: 0.15mm/N | 0.15mm/N
Sd: 810cm^2 | 810cm^2
Vas: 135 l | 135 l
Spl: 88.2dB 1W/1m | 87.7dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: 2-2.6 cuft
Ported box: 2.8-4 cuft @ 28-33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.500”
Displacement: 0.19cuft
If you buy Dual 1 ohm speakers you can end up with 0.25 ohms or 1 ohm.
If you buy Dual 2 ohm speakers you can end up with 0.5 ohms or 2 ohms.
With that in mind... that opens up the possibility for something that does your required power at 0.5 ohms or 2 ohms.
okay, u shouldn't buy the FI Q's since u dont even know what voice coil ur gonna end up getting.
Why? Does that mean he's gotta get subs without voice coils? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
You gotta learn somewhere.
Numerous people recommended him the subs, which is why he chosing them.
bigp69
bigp69
Toronto ON
kicker06
