Need an amp to power 1 15" maw subwoofwer. will buy used.
dude save your money, and get a nicer amp, you will be much more satisfied, if you dont have the patience to wait for more money, then your not going to be happy with the not so good amp
Its 3" dual four Ohm voice coils
Impedance: 4 + 4 Ohm
T/S Parameters (coils in series)
Fs = 26 Hz
Re = 8 Ohms
Qes = 0.35
Qms = 3.35
Qts = 0.32
Mms = 232.8 grams
Rms = 11.42 kg/s
Cms = 0.159 mm/N
VAS = 129 litres
Sd = 756.3 cm2
Xmax = 13 mm
Cone Diameter = 31.1 cm
right off the site. so i need an 8 ohms amp?I dk much about this.
Fs = 26 Hz
Re = 8 Ohms
Qes = 0.35
Qms = 3.35
Qts = 0.32
Mms = 232.8 grams
Rms = 11.42 kg/s
Cms = 0.159 mm/N
VAS = 129 litres
Sd = 756.3 cm2
Xmax = 13 mm
no dude
the MAW-15 is dual 4 ohms (Impedance: 4 + 4 Ohm)
you need an amp that is stable to 2ohms for your sub
i just got the info from mach5audio.com but ill look for a 500 watt rms or more amp. im interested in your amp slammed but idk if it is enough power at 400 rms
BushJ311
BushJ311
NW, PA
budahbuddy803
