Need An Amp For My 15"
danteBirosel
Will be purchasing a "Cerwin-Vega V-Max VMX-15DVC" and will be placing it on a ported box. I have a 1994 Nissan Pathfinder and i already have a seperate amp for my mids.
What kind of amp would be good for my 15"?
Heres The Specs:
Features and Benefits CERWIN-VEGA V-MAX SERIES WOOFERS
MAXIMIZE YOUR BASS with V-Max
The new standard for high performance long throw subwoofers. Diecast aluminum frame, powerful double stack magnet assembly and high efficiency delivers all the boom you need and more!
VMX-15DVC
KEY FEATURES:
* Vega Maximum Throw Suspension
* Rugged Die Cast Aluminum Frame
* Powerful Double Stack Magnet Assembly
* Titanium/Nickel Alloy Plated Diaphragm
* High Temperature Voice Coil
* Designed for Sealed or Vega Ported Enclosures
WOOFER SIZE:
* 15-inch Dual Voice Coil Woofer
POWER HANDLING:
* 400 Watts RMS
* 1000 Watts Peak
IMPEDENCE
* 4 ohms
FREQUENCY RESPONSE
* 20Hz-500Hz
DIMENSIONS
* Mounting Diameter: 14-3/32"
* Depth: 7-1/8"
Heres The Specs:
Im not too familiar with CV subs and if they handle more than rated but if the final ohm load is 4 ohms, there are tons of 2 channel amps that will bridge to 1 channel @ 4 ohms and easily do 400 watts.
what do u guys think about the Kenwood KAC-7252?
Details:
» two-channel car amplifier
» 170 watts RMS x 2 at 4 ohms (250 watts x 2 at 2 ohms)
» 500 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
» high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
» bass boost (0-18 dB) variable from 40 to 100 Hz with wired remote
» Tri-way capable (Tri-Way Crossover required)
» MOSFET power supply
» CEA-2006 compliant
» cooling fan
» preamp- and speaker-level inputs
» preamp outputs
» fuse rating: 40A x 1
» 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
» 15"W x 2-1/2"H x 11-5/16"D
» warranty: 1 year
yea that will work. Actually I just remembered something. If you plan on upgrading your system later on it will be more expensive because you will need to upgrade ur amp also.
so I would probably go with one of these
http://ikesound.com/product-product_id/2167
http://ikesound.com/product-product_id/2424
http://ikesound.com/product-product_id/2668
They will power that sub easily @ 4 ohms and when u decide to upgrade you have the 2 and 1 ohm option that will give you a shit load more power for the subs. Plus I bet they arent any more expensive than that KAC-7252 amp
my budget is quite low, so i was wondering if u guys can refer me to a decent amp that can do the same as those right there. My budget is around the 100s.
Wat do u guys think about that Kenwood Kac-7252 and the CV 15"?
the directed amp is only 155. Like I said before, if you plan on upgrading your system later on, like adding another sub, that 2 channel amp isnt gonna do jack ish. Might as well spend another 50 bucks to get a higher quality class D amp that will push watts at 4-1 ohms
danteBirosel
danteBirosel
San Diego, CA
JoseMCeee
