Need an Amp - Clean power - 2 x 100-150W Amp - Max $200
Just look at the specifications for the amplifier. It will tell you how much power it produces and at what impedance.
Most of everything you find will be stable down to 2ohm.. but just look at the given amps specs.
Not in a mono bridged configuration //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
MOST of everything WON'T be stable at 2 Ohms when wired in that manner.
Yes there are exceptions, certainly, but on average no.
Clean power? If the amp is not clean when run at less than clipping, it's broken... all an amp does is boost your source signal.
I would use the amp you have and lower the gains.
Ruffy
Death to the salad eaters
Ruffy
Las Vegas, NV
gsr22
