need amp
whats the amp do at 2 ohms?
MASSIVE AUDIO P1500.1 Monoblock amplifier (CEA2006 COMPLIANT)
600 watts RMS @4ohms
980 watts RMS @2ohms
1250watts RMS @ 1ohm
1500 watts max power @1ohm (14.4vdc).
Freq. Res@-3dB........8Hz-180Hz
Freq. Res@-1dB.......16Hz-135Hz
S/N ratio (A-Weighted) 1watts ref. >100dB
BASS BOOST @45Hz
Input impedence: 67Kohm
Input voltage: 0.2-5 volts
Idle Current: 1.2 amps
Max Peak Current: 120 amps
Minimum impedence: 1ohm
Required fuse> 100amp
Footprint: 2.6"H x 8.7"W x 16.9"L
This isn't in your range of power I see, but you would be VERY suprised at what this amp can (WILL) do. I have a local running two of these on a pair of TRF12 subs. Sounds really strong. Trying to get him to move up the a pair of P3000.1 amps (which is 2ohm stable).
Please send me an email if interested as I do not go to the forums often.
xmax76@hotmail.com
OR
xmax76@comcast.net
Junior22
Junior22
CT
xmax-1
