need amp that puts out 400wrmsx2
mine does 600rmsX2 ill sell for 200+ship.........its in my sig
Depends on what subs your running but shoudl be fine with 600x2 if ya watch your gains
subs: 2 12" tsw-126dvc
are those subs what this amp will be powering? im assuming they are DVC4?
why not get a 1 ohm stable amp that will do like 1000w to the pair?
yeah i'll be using it will be powering my ts-w126 DVC4 subs. they are cureently hooked up to a cheap bazooka amp that i have had for a while. a 1 ohm stable amp would be ok. could you please find one for me dial-up takes forever?
this will do the trick for you
http://www.millionbuy.com/paka1000db.html
wire your speakers like this and hook it up to the amp
500w to each sub now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
958
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
kile
cutlass
kile
Fort Worth, TX
req
