Need Amp Suggestions for Two JL 10W6v2-D4
what does sq sub mean?
made for sound quality
sq= sound quality- alot of ur subs that sound amazing for all types of music and keep up well
sql= sound quality plus loudness- same as above except they get **** loud and low..alot of ur tc sounds and idmax.
spl= sound pressure level- ur nice sized subs that are made to get VERY **** loud and throw up numbers. your dc level 5's and IA warders are beasts.
I know ill get some hater feedback here... but id save another 100 and grab a 1000/1. Seen a bunch on ebay go for around 400. If your only looking for new, well then disregard my entire post =)!!
Perfect amp setup for the w6s. ive had it for years on a pair of 12's (same 600w rms rating). Because it makes a solid 1000w rms at 1.5ohms to 4 ohms, you can run your subs at 8ohms each to get that 4 ohm load. The amp will run very efficient and make incredible sound with those and pretty **** good output too. Or as forementioned, a pair of 500/1s would look/work sweet too.
Some of the other amps listed are good pics, just throwing in my opinion. I did what you did and eventually got a great deal on a 1000/1 and man was it worth the extra in my opinion.
400 bucks for 1000rms...come on now u can pick up 2 500/1's for around 150 each if that.....
---------- Post added at 02:49 PM ---------- Previous post was at 02:48 PM ----------
stay away from jl audio and there over priced items
Def go two 500/1s if you can get 2 for 300. But if your just going $400 = 1000wrms = overpriced than thats a different direction. i wont argue you can get a more cheaply made amp w/ as much power for $100 on ebay. I think i have some ebay 1800watt amp and im sure its just as good as my 1000/1 right??/
Its like the ricers who slap a turbo on there car and talk trash about beating cars that cost twice as much. they forget that those cars usually come w/ lots of quality parts all the way around, not just mostly plastic or plane jane vehicles. of course theres always exceptions, but im sure you catch my drift.
- And i was like that at one point with my turbo SI, but after getting my WRX and remembering talking trash about them because i could pull on it i realized the difference in quality all the way around. Still i guess just my opinion.
Blackcivic the v1's and v2's are pretty much the same, just v2s will cost a bit more as there newer.
it would be better to run the amp at 4 Ohms instead of 1 Ohm if i do get the jl amp right?
Running the woofers in to the red power band is a BAD idea especially in a ported box. You run the risk of launching the woofer. In your application you can get away with 800 watts no problem. I have done those 2 woofers with a jl500/1 in alot of vehicles and no problems. In a sealed box you could do the JL 1000/1 no problem. If you stick with the ported enclosure make sure the amp you choose has a subsonic filter on it.
blkcivicsedan
blkcivicsedan
hamilton, al
BASSMEKANIK89
