Need Amp Suggestions for Two JL 10W6v2-D4
600 rms will be good, remember you wire the subs at 1 ohm their will be box rise etc. so any amp 1000 to 1500 rms will be good, more power the bette rbecause then you dont have to turn the gain all the way up and will send a cleaner signal.
id do the aq or the american bass for new
the w6 are very picky with power...i would never go over anthing that jl says....i would keep it at 500-600
600 rms such as the audioque or american bass amps, and if you have a 1500rms amp you dont need to crank it up, their is no such thing as to much power if you are smart about it, where people go wrong is when they have a 1000 watt sub and a 1000 watt amp, after rise etc and effeciency, they turn the gain up to the max and bass boost and then fry their coils from distortion which creates heat
audiopipe is crap
S/N Ratio: >70dB,
look at the signal noise ratio please
gonna put a sq sub on an audiopipe
true but anything more i think will not be good for the jl's....1500 on them and im sure they wont last too long
but how ever he does it will work...i wish the phoenix gold xenon 1200 wasnt so ****** rare
brz is a pretty good amp
CADENCE TXA-1000D 1000w RMS @ 1 OHM MONO AMPLIFIER AMP | eBay
id still get the cadence if i was you for those subs, treat a sq sub nice
---------- Post added at 05:31 PM ---------- Previous post was at 05:30 PM ----------
what wire kit? u should really only use 0 or 4 gauge wire....i hate seeing 8 and 10 gauge power wires running amps
cadence wire kit its legit
blkcivicsedan
blkcivicsedan
hamilton, al
BASSMEKANIK89
