Has anyone ever heard of the company before. Series of the amps I seen are called "Encore" made in Korea by NESA. Not sure what that is either. Seen a few of the amps on Egay. Not a bad price if they really put the power out.
Here are some specs.
Amplifier Class : Class D
Number of Channels : 1-Channel
Maximum Power : 5500 Watts
RMS Power Output @ 4 Ohms : 1700 Watts x 1-Channel
RMS Power Output @ 2 Ohms : 2500 Watts x 1-Channel
RMS Power Output @ 1 Ohms : 3200 Watts x 1-Channel
Cutting-Edge Design and Separate end-Cap.(Easy Installation)
1 ohm Stable Operation
Power Supply : DC-DC PWM Power Supply
Power Suppky Design : MOSFET Power
Board Circuitry : Double Sided FR-4 2 oz PC Board
Current Protection : Over-Current, Over-Voltage and thermal Protection
Protection : DC-Draft Protection, DC-Reverse Protection,Speaker Short Protection
System Indicator : Top Monted Blue LED Power Indicator
Variable Low Pass Remote Dash Mounts Gain Control
RCA Output : NI Plated RCA Input Connectors
Crossover : Adjustable Low-Pass, Bass Boost, Phase Shift, Sub Sonic
Gain Control : Adjustable Gain Control
Connector Treminals : NI 2Guage Input Block Type Power Terminal and 4Guage Out Speaker Block Type Terminals
Line Outputs : Non-Pading Pre-Amp Output
Data Link System : Features Allows the Mono Amps ti be Strapped or Bridged Via Master/Slave Configuration
Power Requirements : 14.4V DC(11V to 16V)
Input Sensitivity : 0.2V-8.0V
Frequency Response : 20-150Hz(0,-3db)
Speaker Impedance : 4ohm,2ohm or 1ohm
Signal to Noise : 80dbTHD(RMS) :
Damping Factor : 100
Dimentions : 508 x 223 x 58
Fuses : 30A x 5
Fuses : 30A x 5
