Need an amp for a Re Audio SX 15. Its in a ported box about 4.0@34hz. On a budget don't want to spend too much...
Heres the specs.
Electrical Q Value -Qes: 0.38
Mechanical Q Value -Qms: 4.7
Total Speaker Q Value -Qts: 0.38
Free Air Resonance -Fs: 27.8 Hz
Equivalent Compliance -Vas: 126.3 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 90.4 dB SPL
Effective Piston Area -Sd: 810 cm^2
DC Resistance -Re: 1.9 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 1000 W
Force Factor -Bl: 21
Heres the specs.
