Need amp for a pair of 15" type r. Swr 1522d
  • 4
Bud_toledo
Ohio
Looking for a good budget amp to push my swr 1522d's. I have a budget of $300.
So far I found these amps, not sure of quality or if they have accurate watt listings.
Rub1.2500d sound stream
Ta1.3000d sound stream
Ba7000.1d ppi
Ba5000.1d ppi
Not sure if I should run 2ohm or 0.5 ohm.
I wouldn't try to run any of those amps at 1/2. You're not exactly at the top of the quality spectrum there.
On the other hand, I think any of them would work well at 2.
im running the ppi ba7000.1 amp at 1ohm and its great. does not get hot and has good power. im running it on my sq hdc3 15" and it slams.....
and im going to try it at 1/2 ohm when i get my other hdc3 15.
707
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
981
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Bud_toledo
Bud_toledo
Ohio
Bud_toledo
audiobaun
    May 19, 2024
    May 19, 2024
