Sundown saz 1500v3 and Sundown scv 2000d same boards?
Probably not even though they look identical something as little as different diodes could change the amps completly. Loads of amps use the same biards what makes them different is the components used.
The amp in my pic up there is a ia20.1 and it uses the same board and almost the same layout as the dd m3b. But the dd is rated at 3800 @ 1 ohm at 14.4 were the 20.1 is rated 2400 at the same voltage and impedence.
Jerm1400
Jerm1400
Orlando, FL
Jerm1400
