Need amp advice
iufan71
6
indy
Just getting back into the car audio scene and wanting to put a decent setup in my 97 accord. Going with a Kenwood cd,Boston Pro mids and highs up front and either a jl audio 10w0 or 10w3 single sub. Im looking for advice on a good amp that will run the whole system,so the amp has to have a crossover for the sub built in. I know i could go way bigger subwise,but still need room for groceries in trunk,hence the small single sub. Any amp advice as far and brand name and maybe even models i should consider would be very helpful. Thanks.
Reccomended amp power on bostons are 20-400. Thinking like 100 to each side for those. For the 10w0 jl sub,continous power is 125 watts(reccomended range) and that comes in 4 or 8 ohm. Like i said,not looking to compete or anything,just has to sound good. Any help is appreciated. Thanks.
does it have to be 1 amp? 100 wattsx3 or even x4 is hard to find. maybe do a 50x4 (100x2 bridged), and a 300.1 @ 4 ohms for 150 watts. Then you have a amp that u can use with upgraded sub. Or just a 150.1 if you can find it.... let us know..
iufan71
iufan71
indy
mgaidica
