need advice on what amp to run on a fi audio sp4-18!!!
  • 4
hayleigh21707
hello i have 3 different amps that i would like advice on to whic to use i have a old school soundstream picasso rated at 880 rms at 4 ohms a alpine mrd-m100 rated at 1000 rms at 1 ohm and a american bass ph4000md rated at 2000 rms at 1 ohm now i know whic one is rated higher but has anyone else used that amercan mass to say if its really has 2000 rms at 1 ohm the 18 is dual 2 ohm so i will be able to run the american bass at full petention i would just like to know if anyone has ran one to see what kinf of power is realy coming out of it
ok sweet man thanks im gon be putting tht in a 2 door 04 stratus and i seen some people recomend a sealed enclosure for that 18 and some reccomend vented what would you reccomend there site give specs for both sealed and vented obviously sealed will be eaiser but whic will be louder
Read this
American Bass PH-4000 MD Test | Facebook
---------- Post added at 01:02 PM ---------- Previous post was at 01:01 PM ----------
Ported boxes 9 times out of 10 are going to be louder than sealed
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
OK well I thought the same after watching the Audiofrog video of Andy explaining damping factor. I have to agree with you as well on the D class...
532
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
634
hayleigh21707
hayleigh21707
nitro, wv
Papermaker85
