Need a pair of high end tweeters...
Keep your set and add in a QT4 from Atomic... Welcome to Atomic Loudspeakers its listed under the Quantum section I have a custom 3 way comp system from Atomic and people using Utopia even love the way it sounds. The QT 4 plays 500hz-15k so it will bring out your midrange a lot more and your tweeter. Unless you just want a more harsh sounding tinny tweeter in that case Lanzar DC tweeters 1" handles good power very sharp sounding. They are from the Opti comp set. They have the sound of the old MB Quart Prem line tweeters at way less money. I am an authorized Atomic dealer if you like the QT4 hit me up I'll work with you on price.
Im running the Focal Polyglass VR165 component, I'm planning to keep the woofer and the focal crossovers but change the tweeters to something else.... I like how the MB Quart QSD tweeter sounds so Im looking for something with similar sound quality. I think the Focal TN52 or TN53 will be a good set. Does anyone have a spare set that they willing to let go?
The TN52's are nice if you're a metal tweeter fan, which it seems like you are. Remember that if you're swapping out tweeters to get ones that are the same impedance in order for the crossover points to stay the same.
Wish they had actual specs on the site.
152
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
113
459
352
schoo510
schoo510
Los Angeles, CA
schoo510
    May 16, 2024
    May 16, 2024
