Need a new battery.....which one?
zachzchw
Figure I could stand to upgrade my battery.....Question is, which one? Id like to stay as close to $150 as possible, so that pretty much rules out Kinetik.
I dont play my setup with the engine off hardly at all, so I wasnt sure if I should go with a Yellow Top or if maybe a Red Top would suffice for what I need.
Given this information, what would you recommend?
Those are deep cycle, right? Do I have a need for a deep cycle battery? I thought those were more beneficial if I was running the setup with the car off.Where can I find the exides at?
http://www.remybattery.com give you everything a redtop will give you, plus deep cycle for an even cheaper price. i've dealt with remy and they are an excellent company too. for a daily driver (assuming) and not running with the engine off, i don't see a need to drop a ton of money on a battery, since your amps will run off the alt anyways when the engine is running
Doesn't matter... deep cycles are made to take voltage hits like a champ... unlike the regular red top per say.
So it's just a good idea to get a deep cycle as your starter just because, in preparation for a system... just because.
nG
Hmmm .... I'd go with this one. But it will stretch your budget just a little. I've had a yellow top in the past ... This one SMOKES it easily ...
Agree 100%!//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I run the Stinger SP1700 Power2dB for sound. (same as Odyssey I hear).
I also run the Stinger SP1000 Power2 in the engine.
Great batts, for sure!//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
I run the Stinger power2 1700 as well. They are made by odyssey...wish i had know that BEFORE i forked over the extra cash for a stinger label //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Awesome bat though..even when its -30 outside (not counting the fcking windchill).
zachzchw
zachzchw
ohio
hzsogood
