need a good reliable 4 channel amp
this is alittle under the rms but its a good amp
http://www.cbrstereo.com/index.asp?PageAction=VIEWPROD&ProdID=835
its a rockford fosgate 551x
70 watts RMS x 4 at 4 ohms
140 watts RMS x 4 at 2 ohms
275 watts RMS x 2 in bridged mode at 4 ohms
2-, 3-, or 4-channel output
4-ohm stable in bridged mode
Tri-Way capable
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
MOSFET power supply and output devices
front and rear 50-250 Hz high-pass/low-pass crossovers, 24 dB/octave slopes
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
wired remote control included for fingertip control of Punch Bass (for 0-18 dB of bass boost at 45 Hz)
preamp-level (RCA) inputs
preamp-level (RCA) outputs
12-1/8"W x 2-3/8"H x 9-7/8"D
should be suffient but if u wanna invest a lil more there a good 4 channel alpine amp i believe thats 80 watts a channel
hmm... i've got an avionixx 400.2 for sale. little more power than ur asking for but will give u good headroom. absolutely great amp... pm or email me if u interested.
us acoustics 4085. 85 wrms x 4 at 12.9 volts. well under $200 brand new at sounddomain or thezeb and both are authorized. my 4065 has been real good to me and it's cheap clean power.
I got one of these digital audio da4606c , havent used it long but it seams nice so far, very impressed with looks and build quality. has a fan, neet lookin light, very solid. I got mine for 90 shipped off of ebay, brand new.
http://www.thezeb.com/detail.aspx?ID=1428
it has 2 20A fuses if you are wondering iwas trying to find out when i was looking at buying it but couldent find it on the net so there you go.
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
284
675
441
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
493
goodrich
goodrich
orlando, fl
brandontw
