Need a 15 and an amp - 330 budget
If that's the enclosure you have, I'd try to at least find a sub with the proper hz needs and cuft needs for the design. DC subs usually do good in small enclosures. Especially a 15".
The most difficult thing about the prefab ported box is how hard it is to get that is properly tuned though. Op, I hope you know what the tuning for that box is. Hopefully you can find a sub that will work out for you.
Thinking about going with a Hifonics BRZ15D4 and a CT Sounds 500.1. Would equate to me paying nothing as this is only a temporary system for me, as im selling it to my friend
Or you could buy one of my obsidian audio 15's //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
in all honesty its cheaper to build a box and carpet it... a sheet of MDF / plywood $30....screws 4$.... time = 1-4 hours... that feeling of accomplishment = priceless.
I have this box Amazon.com: R/T 300 318-15 Enclosure Series - Single 15-Inch Slot Vented Sub Bass Hatchback Speaker Box with Labyrinth Power Port: Car Electronics (i know custom is better, but its best I can do)
I need an amp and a sub. Total budget around 330. 360 is the highest id go but less is better. If you need any more info let me know
Boston Acoustics G215 44 15" 600 Watt Dual 4 Ohm Car Audio Subwoofer Sub G21544 690283478599 | eBay
Bravox PXW15D-2 15" DVC Subwoofer 2 Ohm Per Coil | 269-523
way better speakers, i personally would run the boston //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Boston Acoustics GT-275 2 Channel Amplifiers at Onlinecarstereo.com
for the boston
Audio Technix 400 1 Amp Amplifier 400W RMS 1000W Max Class D 1 Ohm Stable | eBay
on the bravox
Needs bigger amp,or at least bigger wire.
amp would be fine on ba and all it requires in 8awg but the at400.1 on the soundqubed sub will be the loudest easily //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Biggiesmails72
Mount Pleasant, PA
Boomsday
