Need a 12" that takes 1000 rms
I am just a beginner, so I guess I have alot to learn but, I plan on power the subs with a Power Acoustik 4000
http://cgi.ebay.com/POWER-ACOUSTIK-PS1-4000D-MONOBLOCK-AMPLIFIER-AMP_W0QQitemZ300295253647QQcmdZViewItemQQptZCar_Amplifiers?hash=item300295253647&_trksid=p3286.c0.m14&_trkparms=72:1234|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
As far as the box goes, I know nothing about building boxes and will probably put these in the regular pre built boxes they sell.[/QUOTE]
do not do that. even the best subs in a shity box will ****. get a box off of one of the box builders on here
you **** at the quotes
I currently own 2 sony xplod 15's and I believe they take around 350 rms each.The type R's are rated for 500 rms, Can they handle 1000 rms on a daily basis?
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh: i could tell you subs that handle less power than the xplods and still be better then them pieces of ****.
Fi Q
Fi Bl
SSA icon
AQ HDC
Sundown Nighshade
Mach5 IXL
IA Death Row and Death Penalty.....
the list goes on...all depends on what your looking for in your system and how much you can spend.
memphis m3alphasonik 812j dual2ohm
diamond d3,d4
mtx 8000
ma audio
power akoustic mofo(the memphis mojo wannabe)
Almost all those subs are rated around 400-500 rms. I am looking for something that is 1000 rms.
Fi QFi Bl
SSA icon
AQ HDC
Sundown Nighshade
Mach5 IXL
My limit is around 120-150 per sub.
i personally dont know any subs around that price that can take 1000rms.
only way would be maybe if you could find one of the one i listed used for sale by a member here or on another forum...
The only ones I found so far are
1) Pioneer W3002d4
2) spl splw-12
I will more than likely end up goin with the pioneers, they seem to be the best sub for the price range. i havent really heard n e thing bad about them, sonixelectronix has a lot of positive reviews for that sub.
Just wanted to see what other options I had.
171
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
126
470
362
gs300tx
gs300tx
Texas
andrewmoore13
    May 18, 2024
    May 18, 2024
