~~~ nate2587's RD worklog ~~~
nate2587
subs:2 15" RD Heavyweight V2's
amps:2 RD 3250.1's (7kw+) I have 1 right now 2nd should be on its way soon
batts: 4+? Kinetik HC2400's
wiring: 4 runs of Tsunami X15 Competition 1/0 Wire
alternator: Stock for now... upgrading in the next month or so
enclosure = teh wall //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
mids and highs: Kicker SS series 6.5's
mids and highs amp:Kicker 650.4 leaves me room with the option to add that other SS set...
The Car
?'s
suggestions?
tools used to run the wire under the car
Custom Fab'ed Brackets made out of aluminum
11ft section of aluminum
Used Bolt cutters to cut the 1/0 wire
The trunk
Nasty egh^?
The wire being run under the car
My buddy Josh aka Whiteboy helping me out with the install really nice guy
Coming down from the Engine Bay
It was a little close to the exhaust so i am going to buy some heat resistant shields to put over the 1/0 wire...
That is coming down from the Engine bay and running down the car
^^ looking from the rear of the car to the front of the car with all the brackets in place
^^ very end of the car last twist needed before i hit the trunk
This is how i mounted the botton board since the Gas tank was right under neath //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif can't very well screw into the gas tank that wouldnt be good
nate2587
nate2587
Lambertville, MI
nate2587
