~~~ nate2587's RD worklog ~~~
is it ok if your power wire under your car is covered with wire loom? thats how mine are ran...(how the previous owner had it that is)
Nice work man, I am looking forward to seeing this finished. I have a 4 door sedan, and in the feature I am thinking I will do something like this.
Did you do anything to your suspension on the car, or is that not really needed?
Not yet but i haven't put in any of the kinetik 2400's in the back yet so i will have to upgrade the suspension in the car before i do that
Not unless you run it like Noah...
Not to hijack too much but what are , and where do you get the connectors on the end of that conduit? Guessin some home depot shoppin is in order.
Looks good and a rather extensive install, props for taking it on.
For the wires under the car: use a buttload of wire ties as you do NOT want the power wires to rub on anything. For spots you can't tie down that might rub, cover them with heater hose.
I've been doing trunk mounted batteries for street race cars for 20+ years with the power wire run under the car and have NEVER had a problem. Wouldn't hurt to inspect things underneath every few months just to be safe.
Good luck on getting it finished, should be loud when it's all done....
tis a rather extensive install but it will all be worth it
hey looking good bro. glad to see you got them. mine is still in cali.//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
they will be there soon! they are worth the wait //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
If u want to at least make the wires a little heat more resistant since closer to the exhaust. take a clear pvc tubing cut it down the middle wrap the 1/0 in that and use a nice like liquid hardner or something to put at the ends so nothing gets in at the end's of the pvc tubing just an idea. but man looks real good keep up the great work man.
Thanks for the idea. should be working on it the next couple of days. Finishing up the resin on the inside of the box and then i still have to cover the front faceplate in vynil and whatnot still got quite a bit to work on //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif but it should be pretty loud after its all said and done //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
nate2587
nate2587
Lambertville, MI
nate2587
vegang
vegang
