Nakamichi PA-4100
mcsoul
such is life
Am I just blinded by it's beauty?
Or is it a steal and just as good as a
SAX-100.4 + ***?
http://cgi.ebay.com/Nakamichi-PA-4100-New-4-Ch-800-Watt-Sound-Amplifier_W0QQitemZ110300991009QQcmdZViewItem?hash=item110300991009&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3911.c0.m14
MOSFET Power Supply - Increase The Amplifier's Ability To Respond To Music Peaks Quickly And Efficiently, With Excellent Sound Quality
Stereo & Bridges Mode Application
Continuous Phase Control (0 - 180 deg)
Terminal Layout At Bottom Of Amplifier
4 Way Protection : Output Short, DC Offset, Thermal & Battery > 18 V
Dual LED Indicators (Power & Protect)
Double Power Output When Using A 2 ohms Speaker
Aluminium PCB For All Transistors - Provide Consistent Thermal Stability
Gold-Plated Power And Speaker Connectors
Power Output RMS @ 4 ohms: 100 W x 4
Power Output RMS @ 2 ohms: 200 W x 4
Bridged Output RMS @ 4 ohms: 350 W x 2
Frequency Response: 20 Hz - 20,000 Hz
Crossover (Butterworth): HP 15 - 400 Hz LP 40 - 400 Hz
Bass EQ @ 45 Hz: 0 - 12 dB
S/N Ratio: >90 dB
Total Harmonic Distortion:
Dimensions: 535 (W) x 63 (H) x 268 (D) mm 21.06 (W) x 2.48 (H) x 10.55 (D) inches # Weight: 6.61 kg / 14.57 lbs
LMK please.
Crossover does not look as flexible as the SAX-100.4,
but man it's a big sexy bitch. I'd love to
see a guts picture.
my friend got one of these hooked up on alpine type r coaxial????//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Do you think it would be a nice thing to swap my mb quart pab4100 for this and little money? I would take the 50 more watt bridged for sure //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I guess it's a little underated too? 100 amp fuse!!!
Aren't you impress by the fact that my friend is using his to power alpine type s and r coax?? c'mon //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
He want to sell his car with this in it, should i try to swap my mb quart 4x100 2x300 for it? Will i notice an improvement in sq ( please don't debate, there is a diff. between amp)?
Try it out and see whichever you like //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
it looks like a lot of adjustments on the crossover and amp to me to bad its not a better pic to read what the adjustments do....i'm not sure how flexible the SAX's are ..
This Nak only goes like 30hz - 400hz high or low pass.
You could not really do a mid/tweet 2 way with it.
The SAX-100.4 can go up to 5kHz to crossover for
the mid/tweet in an active setup. Most folks seem to
be running active off the HU anyway, in which case
it does not matter.
mcsoul
such is life
mcsoul
dfw
mcsoul
