Nakamichi PA-4100
mcsoul
such is life
Am I just blinded by it's beauty?
Or is it a steal and just as good as a
SAX-100.4 + ***?
http://cgi.ebay.com/Nakamichi-PA-4100-New-4-Ch-800-Watt-Sound-Amplifier_W0QQitemZ110300991009QQcmdZViewItem?hash=item110300991009&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3911.c0.m14
MOSFET Power Supply - Increase The Amplifier's Ability To Respond To Music Peaks Quickly And Efficiently, With Excellent Sound Quality
Stereo & Bridges Mode Application
Continuous Phase Control (0 - 180 deg)
Terminal Layout At Bottom Of Amplifier
4 Way Protection : Output Short, DC Offset, Thermal & Battery > 18 V
Dual LED Indicators (Power & Protect)
Double Power Output When Using A 2 ohms Speaker
Aluminium PCB For All Transistors - Provide Consistent Thermal Stability
Gold-Plated Power And Speaker Connectors
Power Output RMS @ 4 ohms: 100 W x 4
Power Output RMS @ 2 ohms: 200 W x 4
Bridged Output RMS @ 4 ohms: 350 W x 2
Frequency Response: 20 Hz - 20,000 Hz
Crossover (Butterworth): HP 15 - 400 Hz LP 40 - 400 Hz
Bass EQ @ 45 Hz: 0 - 12 dB
S/N Ratio: >90 dB
Total Harmonic Distortion:
Dimensions: 535 (W) x 63 (H) x 268 (D) mm 21.06 (W) x 2.48 (H) x 10.55 (D) inches # Weight: 6.61 kg / 14.57 lbs
LMK please.
Crossover does not look as flexible as the SAX-100.4,
but man it's a big sexy bitch. I'd love to
see a guts picture.
my friend got one of these hooked up on alpine type r coaxial????//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Do you think it would be a nice thing to swap my mb quart pab4100 for this and little money? I would take the 50 more watt bridged for sure //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I guess it's a little underated too? 100 amp fuse!!!
Aren't you impress by the fact that my friend is using his to power alpine type s and r coax?? c'mon //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
He want to sell his car with this in it, should i try to swap my mb quart 4x100 2x300 for it? Will i notice an improvement in sq ( please don't debate, there is a diff. between amp)?
Try it out and see whichever you like //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
it looks like a lot of adjustments on the crossover and amp to me to bad its not a better pic to read what the adjustments do....i'm not sure how flexible the SAX's are ..
This Nak only goes like 30hz - 400hz high or low pass.
You could not really do a mid/tweet 2 way with it.
The SAX-100.4 can go up to 5kHz to crossover for
the mid/tweet in an active setup. Most folks seem to
be running active off the HU anyway, in which case
it does not matter.
mcsoul
such is life
mcsoul
dfw
mcsoul
vegang
vegang
