Sold Nakamichi CD500 One of the best SQ decks available $300 sh/py
randyrsx
You already know what this deck is if you're looking at this thread right now. No flash or bling or little finnicky pieces that will fall apart. Just a nice smooth black deck that could pass as stock except for the following specs:
Experience true freedom and power with the CD500 - Listen to any type of music in any kind of format, from CD, CD-R CD-RW to MP3. Rich in features, the CD-500 is packed with all that you can expect of a premium car stereo. From RDS technology to Nakamichi's signature rotary encoder. You will experience the perfection that in-car entertainment can be. With your Nakamichi remote control. You will have even more control over your in-car entertainment unit ever before.
Nakamichi CD500 offers both the convenience of an MP3 and 24-bit premium sound quality. With premium sound quality that is typical of Nakamichis attention to detail and engineering prowess, the Nakamichi CD500 is packed with features such as Rotary Encoder, Synchronized back lighting with dimming control. Designed like any Nakamichi head unit, the Nakamichi CD500 is easy to install, equips with standard security release button feature and its aesthetics would enhance any car interior.
* 9 Colour Illumination Option
* 24 Bit D/A Converter
* 0.005% (1kHz) Total Harmonic Distortion
* MP3/WMA Compatible
* CD/CD-R/CD-RW Compatible
* CD Changer Controller
* Detachable Panel
* Rotary Volume Encoder
* Nakamichi CD500 CD Player Section CD-DA
System Compact Disc Digital Audio
Nakamichi CD500 Error Correction CIRC Principle
Sampling Frequency 44.1 kHz
D/A Converter Type 24-bit D/A Converter
Nakamichi CD500 Frequency Response 20 - 20,000 Hz
Signal-to-Noise Ratio Better than 100 dB
Dynamic Range Better than 90 dB
Nakamichi CD500 Total Harmonic Distortion 0.005% (1 kHz)
* MP3/WMA Section
Numbers of Folders Up to 256
Number of Files Up to 999
Nakamichi CD500 Number of Files Per Folder Up to 256
Number of Folder Layers Up to 8 Layers
Bit Rate
MPEG1 Audio Layer3 32-320 kbps
MPEG2 Audio Layer3 8-160 kbps
Nakamichi CD500 MPEG2.5 8-160 kbps
WMA 64-192 kbps
Sampling Frequency
MPEG 1 32/44.1/48kHz
MPEG 2 16/22.05/24 kHz
MPEG 2.5 8/11.025/12kHz
*WMA 32/44.1/48kHz
Check the feedback forum or ebay id: randyproch
NOW $275 shipped/paypaled. It's as simple as that. I have the box, instructions, pre-out plugs, remote, cage, trim piece, harness, HU w/ faceplate. Everything. Buy it. Do it nao!
PS: Need a new netbook? http://www.caraudio.com/forum/showthread.php?p=6057334#post6057334
$200 shipped and paypaled. I mean really, how could you past this up?
Are you too concerned with getting a "wicked" Alpine deck with all it's tiny fancy buttons?
Or spending your money on a JVC because it matches your dash lighting!?
randyrsx
randyrsx
Behind you!
randyrsx
