Nakamichi Amp Question
andy32844
I have a Nakamichi PA1500 amp running two Sundown SA-12's at 1ohm. I'm not very knowledgeable about sub and amp power but it seems like the amp just isn't enough for the SA 12's. Someone recommended the amp a couple years ago and I've been using it ever sense. I was thinking about upgrading to a better amp. I was thinking maybe a Sundown Amp? Anyone have any suggestions?
for your amps specs https://www.amp-performance.de/en/Nakamichi-PA-1500.html
looks like a good amp and Nakamichi is a weird brand for someone not in the know to stumble upon, but its very solid gear usually.
whats your budget and what gauge wire are you running from your battery to where your amp is? Also, if you go much beyond the 1100 or so watts the Nak is rated at, youre going to want to do the big 3 and run 0 gauge wire if youre currently running 4 gauge
andy32844
andy32844
Port Huron Mi.
youdoofus
ThxOne
    Jun 27, 2026
ThxOne
    Jun 27, 2026
