My very first slot port design.
James Bang
Hand/Ear Coordination
I just tried to design my very own slot port design, and i think it looks like it should be correct, but being my first time, i think it may need some checking. If it's possible, i'd like for some of you experienced designers to double check this plan.
This will be for a 15 Fi Q / SI Mag 15
3.5 cubes after sub+port displacement. sub disp: .19cuft
Tuning will be approx 29.3hz
outer dimensions are 36.5" wide x 17" deep x 16.5" tall
port width x height: 3" X 15"
port length: 33.25"
here's a pic of the layout of the port. i drew a line through the center of the port for the port length... (hopefully that's the correct thing to do.)
thanks.
sweet. I'm hoping that it's correct w/ minimal flaws. I hope to make more designs in the future, so i wanna know if i'm on the right track.
To put in the 45's i make an angle axis thats 135 degrees from the port board then make a line thats port width long on that axis. Then add another axis thats 90 degrees to that then draw a line between the two outside boards on the new axis. Then thats what size the big side of the 45's should be.
like this
your port measurement is correct. i got 3.52 cubes net.
i got a 29.8hz tuning. but its not far enough off to make a major difference.
thanks for the reply. I understand the technique you did w/ the 45s, good info.
as for the volume and tuning, i'm happy with that result. they're not too far off. Thanks again.
//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
successful on my first design.
or am I?
i'm too lazy to use pen/paper.
i use two websites to help and then i use sketchup to lay it out and help w/ dimensions.
I use this site for measurements/volume help:
http://www.the12volt.com/caraudio/boxcalcs.asp#por
and this site for port length help:
http://www.carstereo.com/help/Articles.cfm?id=31
and a trusty calculator for port and sub displacement.
it was a little harder then i thought. Maybe because it was my first time, but it wasn't that bad. profundus-sanus approves so far, so this way works i guess.
James Bang
James Bang
PV Audio
