My tranny is ROYALLY messing up, dunno if I can get to work. P0774
WOT
Banned
As of yesterday, my car started acting up. Its an 02 Qx4 2wd auto.
I already had code P0335 (crank position sensor) and I had just removed/cleaned it and orderred that sensor locally. But yesterday, I noticed my car wasnt shifting properly, on regular aceleration the car will shift into second smooth, but as soon as it goes to shift into 3rd..... tranny slips like a motha, revs up like crazy, sometimes shifts, sometimes the rpms just stay @ around 3k and that becomes its cruising rpm.... its like no power is getting to the tranny/wheels.
When cruusing maintaining the speed limit, it stays @ 3k and when you push the gas the rpms rise but the car BARELY accelerates.
I checked the tranny fluid level in the dark, and it seemed fine, but Ill confirm in the morning when its cold and on level surface.
So I put the scanner on it. P0774 Shift Solenoid E Intermittent
I have the FSM, but cannot find it anywhere in the **** thing. Can anyone point it out to me. Basically I have no idea whats going on here, and I think I may have to borrow my parents car to get to work tomorrow since I work 40 minutes away and give them cab money since there local....
I made a video of the problem and its uploading onto you tube right now, shows the problem much better than I can explain. heres the youtube vid, processing or some bs, Ill try imageshack
http://www.youtube.com/watch?v=3kTOMtans1I
Any help appreciated
Well it threw a code P0774 Shift Solenoid E Intermittent
But I have no idea in english what the means, if its a simple fix, or if I need a load lol
And yes, car in my sig
btw, when in the vid I say Im sticking it into overdrive and say it does nothing, thats just my foot moving the throttle, overdrive usually make the car downshift... but obviously, it did not
I dont know a freaking thing about auto trannies so I couldnt tell you, I dont know if i need a new transmission at this point, or a simple solenoid, and if that part s inside or outside the transmission lol
Was hoping someone would know based off the code I pulled, which i have never heard of before
the part is a small solenoid similar to what they use as a battery relay on car audio stuff but much smaller, it is inside the tranny connected to the valve body get it fixed asap before it burns up the clutches. and you should probably take it to a shop.
The vibrations probably caused the wires to rub against metal somewhere...that takes time 😂
WOT
Banned
WOT
Toronto,CANADA
WOT
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
